please help !
Old Aug 28, 2013 | 03:34 PM
  #31
Oh yeah - 2.2L. Keep us posted on the testing about to happen. this is an odd one.
Old Aug 28, 2013 | 05:19 PM
  #32
Ice on the old ICM yes, but the new one also? Leads toward electrical connection problems causing resistance heat.
Whopper, that's "2006" not "2.2" re:the single coil.
Old Aug 28, 2013 | 10:22 PM
  #33
Donbrew - mine is a 2006 as well, so I think of them by engine size automatically. :)
LOL - did that make any sense at all? What I meant was mine is a 2.4L 2006, and I automatically thought he had a 2.4 with the 4 coils like mine. Maybe I need a nap?
Old Aug 30, 2013 | 06:46 AM
  #34
jack kelly's Avatar
still trying to figure it out!! might be looking at under hood fuse box next, got me stumped.
Old Aug 30, 2013 | 09:39 AM
  #35
hurst2001's Avatar
Just throwing this out there can be a crank position sensor going bad due to heat related problem? I am not sure if the hhr has one, but can be possible .. Hope you find out and let us know
Old Aug 30, 2013 | 01:10 PM
  #36
jack kelly's Avatar
i think it has one will look into it . thank you for the input.
Old Aug 31, 2013 | 03:13 PM
  #37
jack kelly's Avatar
new crank sensor installed , same old b-s thanks anyway. does anyone have some gas and a match?
haha,keep on plugin!!
Old Aug 31, 2013 | 07:15 PM
  #38
jack kelly's Avatar
still no luck, but the more i look innto things the more corroded ground i find, 4 so far will look again in the am .
Old Sep 1, 2013 | 09:42 AM
  #39
jack kelly's Avatar
have found 7 corroded grounds so far, this is b-s. i think gm should stand for get mad !!!
Old Sep 1, 2013 | 11:03 AM
  #40
working on it's Avatar
corroded grounds
Where are they located at? Can you post pics of them? I see you are located in the North, so do you think the corrosion might be related to salt-laden spray from driving on winter roads? Here in Texas, I've never had much of a problem with corrosion, but more from wire insulation breaking down in the heat (especially on older European vehicles). Keep us informed, and good hunting!
