Power mirrors don't work
Old Apr 6, 2013 | 10:24 PM
init1973's Avatar
Unhappy Power mirrors don't work
Hello all, I just bought a 2008 HHR nice wagon runs well only problem is the power mirrors won't work. Any ideas will help. Thank You
Old Apr 6, 2013 | 10:55 PM
Check the fuse in position #21 in the under-hood fuse box, and while you have the fuse box lid off, make sure all the fuses and relays are firmly seated....they have a habit of vibrating loose.
If the fuse checks out, its probably the door switch, check the "Search" function out at the top of the page for "Door Panel Removal".
P.S. to the forum.
Old Apr 7, 2013 | 06:12 AM
init1973's Avatar
Smile
Thanks for the info. I looked thru the handbook and couldn't find a fuse # hopefully this is the problem.
Old Apr 7, 2013 | 09:53 AM
db/sb's Avatar
Page 5-122 through 5-124.
Old Apr 7, 2013 | 05:34 PM
I'll bet your driver door speaker is out, or soon will be (no warning chimes). Water gets past the window molding and causes corrosion in the electrical bits.
sfox410
Sep 22, 2014 03:36 PM
Bob Bolander
Jan 10, 2013 10:31 AM
dfornet
May 31, 2012 08:27 AM
shirar
Jul 17, 2011 02:03 PM
jim2893
Oct 5, 2009 06:59 PM
