power steering fails
Old 08-10-2017, 07:24 PM
alexrckid's Avatar
intermitantly, the DIC on the dash of my 2006 HHR LT displays "power steering" and at the same time, i loose my power steering. happens with i'm driving along at a slow rate of speed...the car has about 116.000 miles on it and runs great except for this problem that's just starting. it is truly intermittant in nature. nothing seems to instigate it. i replaced both fuses associated with the p/s.. a 5 amp in the interior and one 60 amp under the hood. i suspected a voltage fluctuation to the electric p/ s motor(known as a Power Steering Asist Module on the rock auto site)...none. 12.5 in the battery... 13.8-13.9 going back into the battery with all the accessories running. so, now is suspect the p/s electric motor...any ideas anyone....???
alexrckid is offline
Old 08-10-2017, 07:53 PM
Why would you not suspect the well known EPS motor failure for which GM issued an extended warranty for the life of the car ?
https://www.chevyhhr.net/forums/gm-r...tension-50057/
donbrew is offline
Old 08-10-2017, 07:57 PM
Go to your Chevrolet GM dealership, extended warranty service letter for electric power steering motor, if they don't know about it or won't fix it , go to the next closest GM dealership .
Print off this letter
https://consumermediallc.files.wordp...4v153-7510.pdf
And this
http://media.gm.com/media/us/en/gm/v...-steering.html
Mine is a 2007 LS, they have replaced the EPS motor twice!
Oldblue is offline
Old 08-10-2017, 08:14 PM
alexrckid's Avatar
great info, guys....headin to Jud Kuhn Chevy in Little River, S.C. tomorrow to see how i make out.......i'll update this post after doing so..
Old 08-10-2017, 08:20 PM
Looks like most of 2009 and all 2010 is indeed a recall. 2006 through 2008 and the early 2009 get the extended warranty. It may be effectively the same result. In the letter, on page 3, right above Carmen's signature, is the language for the 2006- early 2009. In case your dealer has selective reading impairment.
Everything seems to come in bunches...
RJ_RS_SS_350 is offline
Old 08-11-2017, 04:39 PM
alexrckid's Avatar
update....
stopped by at Jud Kuhn Chevy this afternoon.......explained the issue...pulled the VIN....sure nuff....under the "extended warrenty(2006/115,000 miles). Monday morning at 8:30 getting fixed. sez that based upon the DIC showing "power steering" and the chime coming ..along with the total loss of P/S, that the steering motor/module is to blame....they have it in stock and said that the fix takes no time.....i can sit and wait eating donuts, drinking coffee and reading the paper.....
Old 08-11-2017, 05:08 PM
You're welcome, lotsa people have gone and spent money on their mechanic diagnosing and replacing parts .
This way it's free and you get donuts!!
Oldblue is offline
Old 08-11-2017, 05:59 PM
Greybeard999 is offline
Old 08-12-2017, 08:00 AM
J W Davis's Avatar
I had mine replaced the same way, took all of 15 minutes. Really just 15 minutes, not enough time to drink of hot tea.
J W Davis is offline
Old 08-12-2017, 02:08 PM
alexrckid's Avatar
thanks, everyone......will let ya know how the Monday service visit goes...
Quick Reply: power steering fails
