power steering fails
Old Oct 17, 2023 | 08:10 AM
  #51
That is not at all the symptoms the recall covers. Sound like the motor is not producing enough power. Low battery, loose wire, maybe motor wearing out.
Old Oct 17, 2023 | 09:50 AM
  #52
Lonwane's Avatar
Thanks Donbrew.
I'm not going to worry about the motor failing just looking for warning signs.
Wearing out is a possibility, 17 years and 208,000 miles.
Strong battery 12.4 at rest, wire removed, cleaned and tightened.
Old Oct 17, 2023 | 11:02 AM
  #53
12.4 is a bit low...
What does it drop to when cranking?
Old Oct 17, 2023 | 01:22 PM
  #54
Lonwane's Avatar
Cranking/starting is no problem.
Old Oct 17, 2023 | 06:55 PM
  #55
What’s the voltage when at idle, then at 2,000 rpm? Is the alternator working
Old Oct 17, 2023 | 07:08 PM
  #56
Lonwane's Avatar
12.4 off
13.8 - 14.4 @ idle
14.8 @ 2,00
Alternator replaced 2 months ago
Old Oct 17, 2023 | 07:23 PM
  #57
PulpFriction's Avatar
Used to be, if the battery could start the car, it was good enough. Just not true anymore.
I agree w/ RJ, 12.4V is a bit low. That combined with old corroded high-resistance connections invites trouble.
brazor06
Dec 11, 2022 07:59 AM
le2007will
Dec 11, 2016 07:17 AM
jtangels1954
Mar 11, 2016 02:05 PM
SteveMaine
Dec 18, 2015 11:01 AM
hhrnewbe
Jul 8, 2015 05:34 PM
