Power window motor
OK I see where signal comes from the master switch to the door switch.
But my question is. What is the signal ?
The other thing is the "logic" ?
Do the switches have a printed circuit board in them ?
I don't know why RJ's diagram says 2008 and later, it is 2008 and earlier.
The Master switch in the circuit is the lock button (not on later cars or SS)
What year car?
Here is a pdf for 2010:
Attachment 47665
What year car?
Attachment 47665
Don
Looking at your diagram 12v/30amp from the fuse under the hood (Dark Green) has a junction splice that goes to all four window switches.
But the 12v/20amp from the BCM (Yellow) only goes to the drivers master switch and the front passenger door.
Can you explain the logic of this ?
Thanks.
Thanks.
