Power window switch
Sorry about the scheme.
I bought a separate module "Pandora DWM 210", if you search on YouTube you can find how it works.
When installing there was a problem.
Now I need a schematic diagram of the "express logic" that would bypass the native function.
I read the user manual carefully and thoughtfully.
Thank you.
Would think.
Maybe there's a power window master switch without express logic?
Thank you.
Would think.
I can't find anything in English about the thing.
I don't know what is meant by "express logic".
What we call the "master switch" is the window lock out button. It controls the ground to the individual passenger door switches. Does that help?
That's what I meant (MASTER POWER WINDOW SWITCH):
Agreed. Mistaken.
MASTER POWER WINDOW Switch contains within itself Module "express logic"
That part of the circuit.
Fig. 44: POWER WINDOWs circuit. (2006 system wiring diagrams Chevrolet HHR)
I bought a plug because he forgot to close the windows in the car. Clicking the button on the key fob to lock the car - module pandora DWM-210 closes the windows.
Agreed. Mistaken.
Actually my mistake. I think the easiest thing would be to get a non-driver button, it should just plug in some splicing may be needed. You just would not have the express down function.
I have not had my 2008 for over a year, I don't remember how the switches are attached to the bracket.
Other way is to identify the wires to just bypass the Logic board.
Or splice the Pandora wire into the switch wire on the other side of the logic board.
I am guessing that the Pandora has 4 wires that connect to the "up side" DK BLUE wires.
That is about all I can help.
Sno White - Your explanation of the HHR master switch was aqccurate enough, but the only window that will operate when I operate the buttons manually, is the front (driver side) window - I am guessing that the switch is kaput - any answer - tjmnewknee
I bought a switch off of ebay and took out the housing in the door (no need to remove the door panel at all.) and disconnected the wiring and popped the new one in (1/2 hour). My drivers side rear window would not work on my master switch. all good now.
If you have a pre-2009 no light, but the button is there.
That info can be found in your Owners Manual.
have the same issue I bought my hhr used. the driver side switch stopped working. found the tabs that hold the switch body in place were broke allowing the cir board to drop and no pressure on the pads. used rtv to fasten and that was fixed.
now the passenger side button will allow win to go down but not go up. took apart and the button contacts are belled from pushing. I guess that is why it does not work. lifting the button up to roll up window has far less pressure and I guess it is not making contact
any ideas?
rather fix if possible does anyone know if back door switch is the same?
never use the back seat so if I rob that switch it would not matter.
any ideas?
