powerside view mirrors
Old Jan 28, 2016 | 01:08 AM
LEN's Avatar
LEN
Angry powerside view mirrors
my power rear view mirrors will not work on my 2011 hhr. can any one tell me were the fuse is located. I do not have a owners manual. thanks in advance. len
Old Jan 28, 2016 | 03:10 AM
Courtesy of the SEARCH TOOL at the top of the page, you can download a manual at: https://www.chevyhhr.net/forums/gene...s-manual-3074/
Old Jan 28, 2016 | 07:43 AM
But, it is more likely the switch has failed. They are not expensive check eBay.
Door Mirror Switch Front Left Dorman 901 116 Fits 06 10 Chevrolet Impala | eBay
(This switch also fits HHR's, the "Impala" in the listing that Don has posted is just an example of GM's "Parts Bin" engineering)..843de/Mike
Old Jan 28, 2016 | 09:44 AM
Good morning LEN, check the 5A fuse in position #21 in your underhood fuse box, because you're up in the Snow Belt, I suspect some ice accumulated in one mirror or the other and the fuse popped because of the jammed mirror head.
That fuse is designed to "lay down its life" before a jammed mirror head can strip out the drive assembly, if the fuse checks out as good. And check it visually, and with a DVOM if you have one, then Don's supposition of a bad door switch is next on the list.
Old Jan 28, 2016 | 10:48 PM
LEN's Avatar
LEN
Smile sideviewmirrors
THANK YOU 843 DE. I will check it out. len
Old Jan 29, 2016 | 12:59 AM
Let us know how you make out.
Old Jan 29, 2016 | 08:31 AM
Sometimes just a squirt of contact cleaner will cure the problem with the door mounted switches, but if you have it apart then replace the switch
Old Jan 29, 2016 | 06:06 PM
pg318's Avatar
Mine stopped working a week or so ago, but it's functioning now, probably just froze up.
carid
Sep 22, 2014 07:15 AM
Beachbum1
Jan 26, 2011 01:58 PM
jaysz2893
Mods - Interior
May 17, 2006 11:38 PM
