Rear blinker won't work even with changed bulb
Old Jan 29, 2016 | 02:22 PM
mahiehie610's Avatar
My L-rear blinker isn't working. When I use my L-turn signal, the arrow inside is fast and loud. I checked and the front is working. I replaced the rear bulb but it's still not working. All the fuses look intact.
What could be the issue? It's driving me nuts and I'm sure the people who drive behind me hate that I'm not using a signal when changing lanes or turning.
2010 Chevy HHR
Old Jan 29, 2016 | 02:38 PM
Could be a bad bulb again.
Could be a bad bulb holder.
Could be a bad ground.
Old Jan 29, 2016 | 03:24 PM
Yeah, it has to be either 2 or 3. I changed the bulbs twice.
Old Jan 29, 2016 | 04:56 PM
Next step is to check the socket with a test light or multi-meter.
Old Jan 29, 2016 | 05:20 PM
Did you try turning the bulb around and plugging it back in?
Old Jan 29, 2016 | 05:26 PM
Yes, I did. I was so frustrated.
Old Jan 29, 2016 | 05:27 PM
Ok, I'll have to borrow someone's since I don't have one of my own. Thanks for the tip!
Old Jan 30, 2016 | 12:25 AM
Lucky's Avatar
Will the bulb light when you step on the brake? If it don't work I would be looking for the problem at the back of the car.
If the bulb does light with brake pedal then I would be looking for the problem around the turn signal switch.
Old Jan 30, 2016 | 07:17 AM
CorvetteMongo's Avatar
Often times even though the bulb socket looks good, and the metal connections look good it can still be the contacts in the bulb holder, get a can of electrical connection cleaner from your auto parts store (or Wal-Mart, K-Mart, etc.) The older cars never had problems like that, but the newer ones with the thin wire for connectors are very prone to it...just went through the same problem with my PT Cruiser a couple months ago.
Old Jan 30, 2016 | 08:16 AM
I was also thinking if the car was purchased used , perhaps the previous owner had installed LED lights and resistors, the scotch locks could have damaged the signal feed wire
whitelightnin
May 17, 2014 10:02 AM
eat_world
Feb 9, 2007 08:31 PM
oldschoolfreak
Oct 2, 2006 10:26 AM
hvrod
Jul 13, 2006 01:04 PM
omega015
Feb 18, 2006 11:06 AM
