Pressure switch for AC
Old Jun 21, 2014 | 03:58 PM
db/sb's Avatar
Never heard a sound like that on an HHR. The only time I recall hearing anything remote like that was on my 90 Ranger but the sound was coming from the compressor.
Old Jun 21, 2014 | 09:48 PM
toolbender's Avatar
Originally Posted by Bigpatshhr
db/sb
I've yet to do anything to it yet but when sitting at idle when the compressor is on and blowing cold, there's a loud humming/revving noise sounding like it's coming from the condenser I just replaced. Does that sound like something you've heard?
With the vehicle off, blow air through the condenser. If you can replicate a similar sound, you have loose fins or possibly debris stuck in the fins.
Old Jun 23, 2014 | 08:55 PM
Bigpatshhr's Avatar
Finally found the problem. Changed out the pressure switch anyways since I had to get in there. On my SS the inter cooler piping was changed to an aftermarket which is apparently bigger than stock. There is a vacuum tube and sensor at the bottom before entering into the inter cooler which is pushed tight against the factory pressure switch plug and has rubbed a wire bare. We separated the wires and siliconed it up and it works great now. Will fix it the right way later when I take off the front end to install new. Thanks for all the help.
alfolsee2000
May 30, 2016 08:23 AM
Harpman
Jul 27, 2015 08:09 AM
dodger542000
Tires & Wheels
Sep 6, 2012 09:14 PM
Nukundu
Aug 18, 2010 01:16 PM
andoll83
Mar 23, 2010 06:25 PM
