Problem with 2007 HHR
Old Mar 25, 2018 | 12:33 PM
Then why did you have problems checking the oil level afterwards, as per post no. 6?
Old Mar 25, 2018 | 01:24 PM
Until you decide to provide us with more information, all we can do is make wild guesses. Cars don't just stop working for no reason.
So you drained the oil and changed the filter, put almost enough oil back in. Then you started it, came back in an hour, and it wouldn't start. Maybe it's out of gas.
Old Mar 25, 2018 | 03:41 PM
Monica2000's Avatar
it not out of gas lol I got spark I got gas I am lost that is what happen got home from getting oil for oil change pulled up on ramp an changed filter an drained oil it took for ever for it to register on dipstick came back out to so started right up after pulled off ramp turn off went inside about an hour or two came back out to leave an would not start
Old Mar 25, 2018 | 04:09 PM
Well, that additional information really helps. " it took for ever for it to register on dipstick" - we know, you already told us that. Paragraphs and punctuation would really help, along with answering the questions raised (post 6, 11 etc.)..
About the only advice I can give is - have it towed to a shop, cause you ain't gonna get anywhere trying to fix it over the internet.
I'm out.
Old Mar 25, 2018 | 05:09 PM
When you say you jump started "at the battery", where was that?
Not being mean, it's common for new owners to not know where the battery is in these cars.
Old Mar 25, 2018 | 09:43 PM
Really hard to read this, but,,,,,,,,,,,
Sounds like you changed the oil and filter and then tried to check it with the car still on the ramps ?
No. To be accurate, you should only check the oil level with the car sitting on a level surface.
Samlor
May 1, 2014 01:15 PM
Christinag1125
Dec 10, 2013 12:15 AM
Farmers Daughter
Mar 11, 2013 11:02 AM
GDZHHR
Apr 6, 2007 01:47 PM
ginindy
Feb 11, 2007 12:53 PM
