Problems with miss
Old Apr 21, 2023 | 05:55 PM
Lee3333's Avatar
Those plugs were old ones I had lying around that I tried just as a test I put the newer ones back today. Think this hose could have been the issue?
Old Apr 21, 2023 | 06:40 PM
Those are the correct spark plug numbers in the 06 owner manual I have.
Old Apr 21, 2023 | 08:04 PM
Very much , yes.
I see 41-105 for the 06 2.2L
and 41-103 for the 06 2.4L
Old Apr 21, 2023 | 09:27 PM
If that is the PCV hose ,yes it could cause codes. Also check for cracks in the air horn where it connects.
Old Apr 21, 2023 | 10:23 PM
Originally Posted by Oldblue
Very much , yes.
Perhaps yours is an updated manual.
Old Apr 21, 2023 | 11:24 PM
  #26
Lee3333's Avatar
I think the air horn could also be bad. Do you have any idea what the part is called or the number? I have been searching diagrams but cant find it
After changing the hose, I drove for 20 miles then got the 107 code again It is definitely less frequent, but I need to drive 50 miles before I can get inspected
Thanks again for all your help and ideas
Old Apr 22, 2023 | 07:20 AM
  #27
Air cleaner outlet duct GM Part # 25937095.
Old Apr 22, 2023 | 07:31 AM
  #28
https://www.gmpartsdirect.com/oem-pa...-duct-25937095
I googled that part number here’s one link
Old Apr 22, 2023 | 02:58 PM
  #29
Lee3333's Avatar
Thanks for that information I sprayed all my hoses and that air cleaner duct with soapy water and saw no evidence of any leaks I know that the best way is a smoke test. Wondering if I should try changing the part on the right side of the engine hooked to a vacuum hose-forgot what it is called. A small rectangular box slides on to a bracket. I can photo it later
Otherwise, thinking I should have the fuel pressure checked-could be the pump
Old Apr 22, 2023 | 04:49 PM
  #30
The elbow at throttle body is under vacuum, the cracked hose allows unmetered air to be sucked in after the MAF sensor, that will trigger the code. Undo the two clamps holding it in place , remove the elbow or air horn, and visually inspect it for cracks and deterioration.
You can borrow a fuel pressure gauge at most parts palaces, it should be around 55 psi
