Problems with miss
Is there somethung wrong with using your hands to flex it and your eyes to see cracks.
How did you think soapy water would show vacuum leaks?
The EVAP purge valve is a normally closed valve. The test is to disconnect the tubes and try to blow through it. Usually causes hard start and usually throws a code.
When I removed the elbow it was dimpled. Perhaps????
the EVAP is closed when I blew through it.
Done I have not driven it to check codes yet, but the engine is still running rough It seemed to get its raspy tone when I put on the new catalytic converter. I have a video of the engine but unable to post it here Which you could hear it
