Problems with miss
Old Apr 22, 2023 | 04:57 PM
  #31
Is there somethung wrong with using your hands to flex it and your eyes to see cracks.
How did you think soapy water would show vacuum leaks?
The EVAP purge valve is a normally closed valve. The test is to disconnect the tubes and try to blow through it. Usually causes hard start and usually throws a code.
Old Apr 22, 2023 | 05:58 PM
  #32
Bonez's Avatar
Spray carb cleaner or starting fluid on hoses as its running ( carefully and lightly ) any vacuum leaks and it will rev up.
you can also use a propane torch ( not lit ) it will rev up if any leaks
Old Apr 23, 2023 | 02:29 PM
  #33
Lee3333's Avatar
When I removed the elbow it was dimpled. Perhaps????
the EVAP is closed when I blew through it.
Old Apr 23, 2023 | 04:41 PM
  #34
That looks like it wasn’t on properly, wipe it clean and ensure that it is slide on fully and the clamps are firmly tightened.
Old Apr 23, 2023 | 04:49 PM
  #35
Lee3333's Avatar
Done I have not driven it to check codes yet, but the engine is still running rough It seemed to get its raspy tone when I put on the new catalytic converter. I have a video of the engine but unable to post it here Which you could hear it
Old Apr 23, 2023 | 05:01 PM
  #36
The hose clamp was installed incorrectly, there is a bump in the rubber that fits into a hole in the clamp.
Old Apr 23, 2023 | 06:31 PM
  #37
You sure the gaskets are in good and tight?
Old Apr 23, 2023 | 06:37 PM
  #38
Lee3333's Avatar
yes I know. It has to twist and lock in.
Old Apr 23, 2023 | 06:39 PM
  #39
Lee3333's Avatar
yes. I was working with the mechanic when he installed the new cat. Its all Tight but I'll check again tomorrow
Old Apr 23, 2023 | 06:58 PM
  #40
Impact gun click tight? Or torque wrench click tight?
