Radiator Filler Neck ⚠️ Warning ⚠️
Old Jun 12, 2023 | 02:49 AM
  #41
planetrj's Avatar
Nice! Won't have to worry about that anymore!
Ain’t it the truth! Now on to the next… to figure out the mystery typewriter sound when going over potholes.
Old Jun 20, 2023 | 12:11 PM
  #42
mister hhr's Avatar
Radiator fill neck
I ordered one of those filler neck for the HHR came today my question is the radiator cap does not specify the pressure the cap operates at is this been a problem for anyone?
Old Jun 20, 2023 | 01:01 PM
  #43
It should be a 15 lb psi cap you should be ok
Old Jun 20, 2023 | 01:08 PM
  #44
You see the picture, it has a 1.1, that is bar, which translates to just under 16 psi.
Old Jun 20, 2023 | 01:13 PM
  #45
mister hhr's Avatar
I saw that 1.1 had no idea what it meant thanks for the answer.
Old Jun 20, 2023 | 02:03 PM
  #46
mister hhr's Avatar
Thanks for the response
Old Jan 6, 2024 | 09:06 PM
  #47
Sandstone07's Avatar
I'm so glad I came across this thread. I was about to do a full coolant flush and thermostat replacement after getting "the code" and I noticed the hose from the neck to the engine is beginning to seep. Got the replacement hoses and came here to get some more information. I then decided to replace the neck too after seeing they can disintegrate if old enough and I have no idea if mine was ever replaced prior to my ownership. But, as many have discovered, they aren't available in the stores. However, I found that both Rock Auto and Parts Geek have plenty in stock. I couldn't find the metal ones anywhere so I ordered 2 of the stock ones. Head to either website if you need a replacement. Pricing is $13 at PG and $17 at RA. I went with RA cause they have better shipping options.
Old Jan 7, 2024 | 08:08 AM
  #48
What is "the code"? If you mean P0128 you need a ACDelco 131-158 t-stat. Dexcool has a 5 year life regardless of miles. "Flushing doesn't do much on these engines, even the radiator is aluminum.
Old Jan 13, 2024 | 01:53 PM
  #49
planetrj's Avatar
Yep! I wish I had heeded the warnings by Steve and others who had posted back in 2020, but I had no troubles until trying to twist open/close the cap, and that was the start of the first crack (probably back in early 2022), then when temperatures heated up, that hairline crack opened my eyes to this - what could’ve been a catastrophe.
I found all the parts on Amazon, including the metal filler neck. It’s probably something you might want to do at the next radiator flush. I will never trust plastic filler necks ever again!
Old Jan 13, 2024 | 08:27 PM
  #50
