Radiator Filler Neck ⚠️ Warning ⚠️
Old Jan 14, 2024 | 10:11 AM
  #51
jimvw's Avatar
finally got around to looking at this thread. Seems like my cap is difficult to install and remove, and I think it has internal threads (not sure) but I have wondered if it could fail some day since it is a 2006...Just ordered a replacement off Ebay. Right now it is a blistering -11 degrees out so it may not get replaced for a bit, the original one is still working but it would be just my luck that it would fail if I didn't have a replacement on hand.
Thanks for bringing this to my attention. should be here in a few days...
Old Jan 14, 2024 | 01:44 PM
  #52
Get a pair of stainless steel worm gear clamps for the install
Old Jan 14, 2024 | 07:57 PM
  #53
planetrj's Avatar
I second this
Old Jan 14, 2024 | 09:03 PM
  #54
Checked my OE one today, it is good at this time.
Old Jan 16, 2024 | 03:36 AM
  #55
geg's Avatar
geg
my filler neck died a few years ago, a metal replacement was purchased through a Chinese site, alive and well to this day.
I didn’t buy new clamps; I used old clamps with a spring compression principle.
Old Jan 16, 2024 | 09:24 PM
  #56
Next time I do the Dexcool change, should get a metal replacement.. Good info.
Old Jan 27, 2024 | 05:37 PM
  #57
Sandstone07's Avatar
Originally Posted by donbrew
What is "the code"? If you mean P0128 you need a ACDelco 131-158 t-stat. Dexcool has a 5 year life regardless of miles. "Flushing doesn't do much on these engines, even the radiator is aluminum.
Yup, that code. I already knew of the thermostat and I did get a genuine ACDelco.
Greg Bystritski
Oct 15, 2020 06:27 PM
lauriej
Mar 12, 2020 04:30 PM
aradmahogany
Maintenance and Upkeep
May 20, 2018 09:03 AM
donbrew
Apr 24, 2015 05:22 PM
gilldoht
Jan 5, 2013 06:13 PM
