Radiator Leak in cold
Old Jan 17, 2024 | 12:22 PM
Lethal Tendencies's Avatar
So I had to put my '11 outside over night and it was was - 13 degrees. Now I developed a radiator leak in 2 places. It only leaks when car is running. Can't pinpoint yet where its leaking from. LT with 97,000 miles. Car is normally garage kept and is very clean condition ( no rust ). Coolant did not freeze so I not sure where to look
Old Jan 17, 2024 | 12:32 PM
Check the clamps at there are 4 on the upper hose, and 2 on the lower hose.
check the rad cap filler tee. For cracks, loose cap.
Old Jan 17, 2024 | 02:25 PM
From the radiator for sure? The washer pump is known to freeze and fail.
Old Jan 17, 2024 | 02:41 PM
How old is the coolant? It may not have frozen in the filler neck or hoses, but maybe did in the tiny radiator passages (if the coolant is old, that is).
Old Jan 17, 2024 | 02:44 PM
Thanks for the ideas
Old Jan 18, 2024 | 03:46 AM
geg's Avatar
geg
There are compounds that eliminate small radiator leaks.
If the radiator itself is damaged, you can use this.
Many years ago I used this as a temporary measure while a new radiator I ordered was on its way to me. As a result, the new radiator not only arrived, but also waited for its turn for more than three years.
By the way, the chemistry was American, called Hi-Gear, a lilac tin can..
Old Jan 20, 2024 | 10:11 AM
BlindLizard's Avatar
Back in the day household black pepper. Can u still do that with newer cars?
Old Jan 20, 2024 | 10:23 AM
I wouldn’t, might clog up the heater core! And we know changing that heater core is a huge PITA!
Old Jan 25, 2024 | 02:46 PM
I ordered a new radiator. Thanks for the help
Old Jan 25, 2024 | 03:45 PM
You are sure it’s a leaking rad?
vicmon
Oct 1, 2019 09:20 PM
Frank Larrabee
May 10, 2018 08:04 AM
SamuelJ
Nov 16, 2015 03:45 PM
AJL08SS
Jan 27, 2014 08:25 AM
crazysteve
May 23, 2008 01:46 PM
