Random plate gasket for intake manifold
Old Aug 16, 2024 | 07:00 AM
Happy to help! Enjoy the ride!!
Old Aug 17, 2024 | 09:51 PM
fastsuv's Avatar
A little late, but I took the intake manifold off my daughter's 2011 2.2L (I'm replacing the engine) and took the following pictures:
The intake manifold side:
The head side:
Steve
Old Aug 18, 2024 | 07:14 AM
Thanks Steve! Conclusive evidence, for future readers!
Old Aug 18, 2024 | 09:13 AM
Look like you lost the plate too. It is meant tp block the hole in the head. Maybe the Cobalt had a use for the hole?
Old Aug 18, 2024 | 11:07 AM
The plate is in the head between #2 and #3 intake ports.
Old Aug 18, 2024 | 08:58 PM
  #26
The outline of the plate is there but the hole is visible.
Old Aug 19, 2024 | 07:13 AM
  #27
Yes the hole is visible in the post #1 photos also. That provides vacuum for the MAP sensor.
Old Aug 19, 2024 | 08:18 AM
  #28
You can see the hole and the outline of the plate. The plate is missing in both pics.
The pic in #4 shows the plate in place.
Old Aug 23, 2024 | 07:27 AM
  #29
fastsuv's Avatar
I looked closer at the "plate" area after cleaning the head surface a little.
It turn out there is NO plate. The O-ring on the intake kept the area inside the O-ring clean, while the area outside the O-ring corroded because it was exposed to the air. This gave the look of there being a plate.
It's just the surface of the head with a hole in it.
See the picture below:
This is on the engine that is being replaced, the original 2.2L in the 2011 HHR 1LT.
Steve
Old Aug 23, 2024 | 07:30 AM
  #30
Maybe earlier heads had the plate then they changed castings for the LE9
TwoElTee
Jun 24, 2021 06:03 AM
jjredsoxfan
Apr 19, 2020 08:16 AM
jmule
Aug 10, 2015 11:21 AM
SS fan
2.0L Performance Tech
11
Mar 8, 2011 03:16 PM
hhr_2009
Mar 17, 2010 07:20 AM
