Raw gas oder
Old Feb 24, 2019 | 04:02 PM
X2 replace both the fuel pressure line and the vapour line.
Old Feb 24, 2019 | 04:35 PM
New fuel lines needed...
Old Feb 24, 2019 | 05:08 PM
I read the OP's other 2 posts in another thread he had. Appears that this may be the same issue he had before that has now gotten worse.
Pelliott321. Did you check/fix the fuel and vapor lines several months ago regarding your fault code and failed emission test ?
Old Feb 24, 2019 | 10:15 PM
Thanks for the heads up FMG, threads merged.
Old Feb 25, 2019 | 08:28 AM
pelliott321's Avatar
thanks for the responses
I see now how my problems might be related. The Engine light and Code did finally clear
I everything was fine for a few months until the raw gas smell and finally the leak.
Its going to be warmer today in Baltimore I will jack the car up and take a look see
Thanks for the responses.
Old Feb 26, 2019 | 08:44 PM
alexrckid's Avatar
Originally Posted by pelliott321
2009 LS HHR 84K miles
for the last week I noticed a strong gas smell each time I got out to the car. For the last couple of days it took a couple more revs of the started motor to start the car. This morning there was some raw gas on the ground just in front of the driver side rear wheel.
I'm thinking something to do with the EVAP system
Any suggestions
Thanks in advance
absolutely a FUEL LINE leak.....wont get a puddle with the evap line leaking. they run side-by-side along the underbody and have a "weak spot" right over the drivers/rear side where the two lines bundle together and hold moisture. line(s) rust and leak.......fixed mine a few years back on my 2006 HHR with new high pressure lines from Chevy. PITA job but well worth it.
KChhrSS2008
Feb 22, 2013 12:40 PM
bigjacksauto
Apr 9, 2012 05:05 PM
bartSS
Mar 12, 2011 11:42 AM
SIHHR
Jan 10, 2007 02:44 PM
