rear doors
Old Jan 9, 2013 | 07:05 PM
Buck Meyers's Avatar
rear doors
I have a 2008 hhr panel and the rear doors won't pop opean. did the tsb chevrolet had out by washering the popers, didn't help. doe's anyone know if there made by a aftermarketer? I also have a SSR and have mutch better luck with after market parts. ps my hhr only has 5000 miles on it.
Old Jan 10, 2013 | 12:17 AM
They don't 'pop' with the fob or the dash buttons ?
Old Jan 10, 2013 | 05:27 PM
both, the rs is better the drivers side you have to pull it opean at the top of the door, the popper dosen't push it opean.
Old Jan 10, 2013 | 07:21 PM
VinceP's Avatar
I have found that if I clean the gaskets on mine and keep them lubricated with a little silicone grease they work alot better. Plus the grease helps the gaskets last longer.
Old Jan 10, 2013 | 10:22 PM
X 2
Old Jan 16, 2013 | 07:44 AM
Tryed that first with gm rubber lube , did not help
playgames1970
Sep 1, 2014 01:57 AM
HUNTMASTER
Mar 15, 2014 12:14 AM
songman1505
Sep 10, 2012 11:50 PM
Buck Meyers
Feb 7, 2012 08:03 AM
