rear hatch
Old Dec 28, 2012 | 08:34 AM
@capp002, how are things going at trying to get ride of the noise? Creaking rattles and squeaking really get on my nerves. LOL I hope you are getting this resolved.
I hope you have a wonderful New Year’s Eve celebrating and be safe.
I’ll be out of the office from 4:30pm EST today through 01/01/13.
Old Dec 28, 2012 | 09:53 AM
Musicguy's Avatar
Originally Posted by skyline26
mine sound like the gas shocks are dry, ive tried lubing them, hinges and the stops yet it still makes squeak noise
did you lube the latch on the floor at the contact point, which is not where you would think?
Old Dec 28, 2012 | 01:26 PM
capp002's Avatar
Thanks michelle same to you. Well i just put some lube on the rubber stops il see tonight:twothumbs
Old Dec 28, 2012 | 03:08 PM
You’re welcome, capp002! Let me know how things are going when I come back on 1/2/13.
HAPPY NEW YEAR!!!!!!!!
Old Mar 10, 2013 | 08:12 AM
slinger569's Avatar
I was just wondering what the outcome of this was? I have that annoying squeak, I blasted it with some WD-40 but it didn't help.
Old Dec 9, 2020 | 07:42 PM
MN Murph's Avatar
Cranking continues post white lithium grease.
There are two issues that I'm sure are the same issue:
  1. The hinges creak a binding creak when opening especially, cold weather increases the intensity; and,
  2. The door doesn't want to open all the way. It had to be pushed up.
I have lubricated with wd-40(in the beginning), but it doesn't have enough 'staying power' for this. White lithium grease/spray...the cold that causes it seems to also dry it out, or it gets worked out with time... Periodic maintenance is probably the easiest solution here, apply a heavy weight grease of your choice. I have observed that the hinges appear to be set in such a way that binding occurs...(it's obvious when you look at it, like a wrongly hinged clam shell. It's off.) That puts the strain on the system. I'm looking into affording heavier duty hatch struts. Anybody know about how simple that'd be?
Old Dec 9, 2020 | 07:55 PM
I replaced my struts with a set from RockAuto, no binding, they lift the latch fully. Perhaps your struts just require replacement. I do lube mine with white lithium grease in a tub, just a dab on the ball or the pivot every six months, once in the fall and again in the spring.
the low price ones for $9 each.
https://www.rockauto.com/en/catalog/...t+support,1404
Old Dec 10, 2020 | 07:57 AM
MN Murph's Avatar
Replace strut, and grease periodically
Thanks, will try it. Looking for new struts 'as we speak'? (so to say).
HHR_Bandit
24
May 23, 2014 03:41 AM
Lethal Tendencies
Jan 29, 2010 08:49 PM
06Daytona
May 14, 2009 11:12 AM
sparklyj
Apr 3, 2007 08:24 AM
