Rear washer spray pattern
I bought my 08 HHR used, and the rear washer has always dispensed fluid in two single streams, like this /\, with no "spray" dispersion like the front washer does. Is this normal?
Its been a long time since I accidentally activated the "rear glass scratching function", but the pattern is an inverted "V" with fairly good dispersion.
Grab a sewing needle or pin and gently clean out the spray nozzle orifices, that'll remove the washer fluid crust so you get a better pattern.
