Rearview mirror map light button issue
Old Jun 28, 2019 | 09:18 PM
mrmarkuSS's Avatar
After reading about 6 threads on the rearview mirror map lights,it does not apply to my problem.
The problem is,if you turn on the map light,it is a pain in the ass to turn off. Seems that the push button switch is faulty,and it's one of those newfangled switches that make a contact on a printed circuit board. If you push too hard,the button pops inside the mirror,necessitating a removal,disassembly,and put the button back in place.
What I want to know,are these buttons replaceable,or do I need a new mirror assembly?
Old Jun 28, 2019 | 09:55 PM
I doubt they are sold separately.
You might try a bit of metal foil under the button.
Old Jun 29, 2019 | 07:36 AM
Or clean the contacts with an eraser, most likely a touch of corrosion.
A new mirror or a used one , PM hellshotrod, his is parting out HHR’s
Old Aug 28, 2019 | 06:44 PM
Jay23's Avatar
I was rotating rearview mirror when was installing a dashcam.
After that, the mirror became too dark - how to fix it???
Old Aug 28, 2019 | 06:54 PM
What does that have to do with this thread?
You probably flipped the day/night switch. I bet there is a section in the Owner Manual. There it is on page 134 of the 2007 Owner Manual.
Old Aug 28, 2019 | 08:33 PM
Jay23's Avatar
Actually, I wanted to post that question in my thread but was looking before. Why r u so angry?
Old Aug 28, 2019 | 08:35 PM
Jay23's Avatar
where is that switch located? There is some button like a Power or smth. I tried to press it hold it -nothing changed(
Old Aug 28, 2019 | 09:38 PM
It depends on which mirror you have.
Not angry, where did you get that?
This is the autodimming without OnStar. On the manual type it is the toggle in the bottom center
Old Aug 31, 2019 | 09:47 PM
Jay23's Avatar
mine is the same. What for that Power button? I pressed it and nothing changed except LED turns on/off
Old Sep 1, 2019 | 09:20 AM
I guess it is broken. The 2 black buttons are supposed to control the lights.
The way they work is by a prism so maybe by manipulating the mirror up/down it will change. I never had that kind of mirror.
Jeda13
Dec 19, 2009 02:53 PM
krooozn
Sep 21, 2009 09:12 AM
UncleDannie
21
Aug 28, 2009 12:32 AM
trfindley
Nov 10, 2008 01:31 PM
JOEK86
May 7, 2006 08:27 PM
