Red Brake Light on Dash - Not Parking SW or Fluid Level
Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
You stated earlier - "The "Check Engine" light is most likely due to the intake and/or exhaust camshaft position solenoids. It's been on for several months" - what exactly makes you suspect that it is the solenoids that are needing replacement, when you have not downloaded the CEL error codes?
When the Solenoids go bad, they not only generate the P0010/11 and/or P0013/14, but typically generate the abrupt changing of the gears in the tranny - and you say you have not noticed that side effect.
You have already spent $2131.53, with another $2483.14 to be done - why spend an additional penny on something on spec?
and the dealer charging $140+ to replace the serpentine belt is way excessive.
An hour, geez , it takes me that long , getting all the tools and jack and stands. Taking off the splash shield . And answering a phone call or two. Talking to a neighbor . An hour, and they have the correct tensioner tool? If I had one , the belt would be a 5 to 10 minutes, and done
...When the Solenoids go bad, they not only generate the P0010/11 and/or P0013/14, but typically generate the abrupt changing of the gears in the tranny - and you say you have not noticed that side effect.
You have already spent $2131.53, with another $2483.14 to be done - why spend an additional penny on something on spec?...
The only work I had done at the dealer was the left hub bearing. I repaired the other "done" items myself with the exception of the alignment and injector flush (done at another shop after lower control arms).
The solenoids cause abrupt shifting? I was under the impression that they changed from one set of cam lobes to another. One tuned for cruising speeds and the other for quicker acceleration. I'll have to research that further.
Boy are you wrong! VVT stands for Variable Valve Timing, it is constantly changing. It causes hard shifting because it induces limp mode, also to wake the driver up so he will notice the CEL. Also turn TC off.
They took you for a long ride on the hub replacement! parts stores sell them for about $140, much cheaper on eBay, labor is less than 1 hour. GM gets $360 for the part.
