Reduced engine power
Old Mar 30, 2022 | 01:16 PM
  #31
The battery lobotomy, disconnect the negative cable only for a full 30 minutes. If you have done this , then you know that did not work.
Old Mar 30, 2022 | 03:21 PM
  #32
PulpFriction's Avatar
Originally Posted by Jasonw7684
It all started with the head lights. First it started blowing fuse for steering motor, found out my headlight connectors were burnt so I replaced them. Things straightened up then it started giving the reduced engine power with the p1682 code.
A sucker for a good mystery, I was just re-reading this thread and caught the part about the power steering motor.
Can you elaborate on any power steering issues? A bad motor could cause crazy power draws and wreak havoc. If there’s any chance of a bad ps motor, it’s likey covered by either the recall or the extended warranty.
Old Mar 30, 2022 | 06:07 PM
  #33
Jasonw7684's Avatar
I haven't had any issues with the power steering except it was blowing fuses but once I replaced the burnt headlight connectors it quit blowing that fuse.
Old Mar 30, 2022 | 06:10 PM
  #34
Jasonw7684's Avatar
I did disconnect it once like that. Right now it is disconnected and has been for 2 days. Guess when I get alternator back on I will see for sure
Old Apr 5, 2022 | 10:07 PM
  #35
Jasonw7684's Avatar
So I replaced serpentine belt and put It back together, this was day 2 of her driving it and there hasn't been any issues.
Old Apr 6, 2022 | 06:38 AM
  #36
So the alternator wasn’t working properly, because of the serpentine belt was worn out. Thanks for the update.
Enjoy the drive!
Old Apr 6, 2022 | 10:41 AM
  #37
There is a recall covering the power steering. Headlight fuses have no connection to the PS.
Check for recalls & extended warranrees
Old Apr 28, 2022 | 07:35 AM
  #38
Jasonw7684's Avatar
Well that was short lived. Throwing same code and giving reduced engine power again.
Old Apr 28, 2022 | 07:43 AM
  #39
Kindly refresh my memory, what were those codes?
Old Apr 28, 2022 | 09:02 AM
  #40
The only code mentioned in this thread is P1682. You got distracted by the charging system, this code is ignition related.
Have the ignition related recalls been performed? https://www.chevyhhr.net/forums/gm-r...-status-50716/
