Reduced Power
Old 01-31-2011, 09:34 AM
hockeygirl777's Avatar
Reduced Power
So yesterday my 07 HHR LT went into reduced power after about 5 seconds of driving, thank god my boyfriend was with me and had his scanner. The code was P2135 which has something to do with the throttle position sensor. My boyfriend thinks it may be the throttle body (from the info he found on alldatadiy.com, he is also ASE certified and works for a local Chevy dealership in case anyone wanted to say how much he doesn't know). We cleaned off the plug that plugs into the throttle body and it seemed to be working fine last night, but I was just curious if anyone else has had this happen and what they had to do to fix it, Thanks.
hockeygirl777 is offline
Old 01-31-2011, 09:38 AM
Sounds like you have the right Man around the house suggest you feed him well!
SS fan is offline
Old 01-31-2011, 09:44 AM
Hahaha... I definitely agree. I'm not responsible for feeding though, mostly housekeeping, which I think he purposefully makes a challenge.
Old 01-31-2011, 09:50 AM
I think thats a man thing we aren't happy lest we leave a trail of clutter every where we go. It's like marking our territory.
SS fan is offline
Old 01-31-2011, 03:04 PM
Update:
I just tried to drive the HHR and didn't even make it out of the driveway before the reduced power happened again. Boyfriend is bringing home a throttle body after work so I will let ya'll know how it works out.
Old 01-31-2011, 03:21 PM
Seems to be a string of throttle body issues lately hockeygirl, my first thought on reading your post was...here we go again. You'll probably find the throttle body swap cures the problem, but keep us posted.
843de is offline
Old 01-31-2011, 05:20 PM
Lucky's Avatar
Anyone know what fails in the throttle body?
Lucky is offline
Old 01-31-2011, 06:01 PM
LawDog88's Avatar
@Lucky. The assmebly. I had this code 3 times. Finaly time was because of a frayed wire into the throttle body assembly. Fixed that. Working since.
LawDog88 is offline
Old 01-31-2011, 06:15 PM
Changed the throttle body and it's still broken.
Short reply= me being pissed off
Old 01-31-2011, 06:19 PM
Sorry ; We are all rooting for you
SS fan is offline
Quick Reply: Reduced Power
