Relay Direction
Old Feb 23, 2022 | 08:25 AM
jimvw's Avatar
That's it exactly. I cut it open to figure it out. First time I have seen this type of arrangement and I am used to relays with diodes we use for digital circuits. Donbrew was correct in what he said. these new fangled things are tough on us old mechanics!
Old Feb 23, 2022 | 11:43 AM
If there is a diode it will be on the diagram on the side. Some do have a diode they have a key. The fan has a diode in the harness a couple on cm from the fan.
Old Feb 24, 2022 | 05:03 PM
jimvw's Avatar
New fan arrived yesterday, and last night when I got home, it was 3 degrees out, driving down the alley the temp hit 205. I tried switching the A/C on and setting it on high, the temp dropped to 192 after a few seconds. so maybe the fan works?? i didn't open the hood as it is in a snowbank and the ground beneath the snow is coated in ice, and it was 12:30 in the morning. (just full of excuses) If and when temps get above about 40, I'll be putting the fan in and swapping the thermostat, just so it is done.
Old Feb 24, 2022 | 05:11 PM
jimvw's Avatar
Anyone recognize this plug? found it in the fuse box under the hood... Quarter is for size comparison.
Just curious..
Old Feb 24, 2022 | 06:40 PM
Loose in the fuse box? Anybody’s guess
have a look here , maybe it’ll show up
https://www.chevyhhr.net/forums/how-...rmation-59520/
Old Feb 24, 2022 | 07:25 PM
Gearhead1's Avatar
Do you have wiring diagram that shows how the fan relay and circuit works? …usually the coil circuit in the relay either has power to it all the time and temp switch completes the ground…or vice versa.
Old Feb 25, 2022 | 08:12 AM
Lonwane's Avatar
I have a plug/cover similar to that over the power steering lug at the under hood fuse block location.
My thought is that it was installed by POV to prevent jump start cables from being attached there.
speedwagen
May 18, 2022 11:11 AM
jasguer
Nov 16, 2021 08:04 PM
RF2
Jun 24, 2018 03:32 PM
marilynferguson95
Dec 17, 2016 12:47 PM
ejb1982
Jan 31, 2013 01:59 AM
