Replacing head gasket
Old Aug 9, 2024 | 11:53 AM
Fakeadamdriver's Avatar
In general, is it worth replacing the head gasket in my 2010 HHR LT with about 107,400 miles on it? I could probably get only about $2000 to $2400 on it in my local market, and it seems this replacement would cost nearly the entire value of the car.
Old Aug 9, 2024 | 12:16 PM
Why replace it?
Old Aug 9, 2024 | 12:39 PM
Depends on your intentions for the car, are you gonna keep it? Then yes! Are you gonna sell it , then no!
are you capable and have the tools? Or do you have to pay labour and machine shop fees?
Old Aug 9, 2024 | 09:43 PM
Thanks, the problem is it heats up too quickly, especially in hot weather. But I think the best thing to do is to not drive it much and sell it in a few months.
Old Aug 9, 2024 | 10:13 PM
Heats up too quickly, is it losing coolant? How was the head gasket diagnosis made?
Old Aug 9, 2024 | 10:31 PM
Randy. Read their other thread about the car overheating. I suggested then that they could have serious engine damage.
Old Aug 9, 2024 | 10:34 PM
"heats up too quickly" by itself does not suggest head gasket. Sounds like you are looking for an excuse.\ for a new car.
Old Aug 10, 2024 | 03:08 AM
PulpFriction's Avatar
This is the one that was driven dry and severely overheated.
In such a case, if the head head gasket is now leaking, the head is surely warped, and it will need more than a head gasket.
How nice is the car? The question is, will properly repairing the car result in a car that’s worth more or less that the cost of replacement with a similar car?
But it’s not even clear what needs to be done.
I don’t understand what is meant by “heating up too quickly.” This needs clarification. Heating up promptly to the proper operating temp of 180-190 is good. Continuing beyond that is bad. The severe overheating probably ruined the thermostat. Was it replaced? From the prior thread, the OP doesn’t understand what a thermostat is or does.
Old Aug 10, 2024 | 07:36 AM
Usually heating up quickly is from low coolant . Have you done a compression test to verify a bad head gasket?
Old Aug 12, 2024 | 09:27 AM
*poof*
Aj1968
Aug 20, 2023 05:25 PM
carnutbill
Jul 3, 2022 02:42 PM
Mike's SS
29
Mar 23, 2021 03:04 PM
chrispacekc
Sep 28, 2020 07:26 PM
cj-five
Dec 7, 2014 03:29 PM
