blown head gasket
Old Mar 4, 2016 | 11:18 AM
Mike's SS's Avatar
blown head gasket
I've got a 2009 HHR SS, with a blown head gasket. What head gasket set would you recommend?
Old Mar 4, 2016 | 12:13 PM
DrLoch's Avatar
A GM head gasket. Can you maybe provide a little more information? This is not a common problem with a SS.
If you have any miles on it you will want to replace the timing chain an guides while your at it.
Old Mar 4, 2016 | 12:23 PM
X2 plus a water pump.
Old Mar 4, 2016 | 12:36 PM
X3 !!
Old Mar 4, 2016 | 04:12 PM
Mike's SS's Avatar
My 2009 SS has 84,000 miles on it. It's building up pressure in The coolant system, when its running. And runs a little hotter than normal. A friend of mine ran a pressure test on the coolant system and there were no signsof leakage.
I was told that, that was the signs of a blown head gasket.
Any ideas or advice?
Old Mar 4, 2016 | 04:32 PM
A compression test and a coolant system pressure test will determine a bad head gasket.
I'm of the school, pull the head, have the machine shop do the valves and head surface
A new timing chain and gears set, a water pump and head gasket, and enjoy the SS for another decade or so
Old Mar 4, 2016 | 04:55 PM
Isn't it normal for the pressure in the cooling system to rise as the temperature rises? Or is the pressure outside of the normal range?
Old Mar 4, 2016 | 05:10 PM
Before pulling the head, you should test the coolant for contamination. There are test kits available at parts stores. This would tell you if a blown head gasket was forcing combustion air into the coolant system.
Now, you didn't state a loss of coolant, but if that's happening, then pull the spark plugs and check them for signs of coolant burning in a cylinder.
I would try these 2 things first to verify it is actually a head gasket problem.
On a side note. If the car has ever run over 260 degrees, then you probably do have a head gasket(or worse) problem.
Temps that extreme will usually spell the "kiss of death" for the LNF engine.
Old Mar 5, 2016 | 08:11 AM
DrLoch's Avatar
You didn't mention it, is this a stock SS with nothing else done to it? If the other suggestions aren't an issue it could be that the stock stat is the cause.
Old Mar 5, 2016 | 10:22 AM
IF the pressure was too high (over 15 PSI) & the pressure cap is good coolant would be pouring out the recovery tank?
