blown head gasket
Old Mar 16, 2016 | 07:04 AM
Burping it. Park it nose high, cap off, run it till it burps.
The fact that the heater works but the radiator stays cold makes me think "bad t-stat".
It is a 180F t-stat? Recently we have heard auto parts stores selling 190F t-stats.
Old Mar 16, 2016 | 08:20 AM
Mike's SS's Avatar
Yeah its a 180 stat.
I got on you tube and looked up, the how to on burping coolant systems. I may have to try a new stat. Again
Thanks don
Old Mar 16, 2016 | 08:54 AM
Park the HHR nose (front bumper) about a foot higher then the tailgate, let it cool down a few hours, open the rad cap to let it burp and top up the Dexcool.
Is it an AC Delco thermostat? If not get one!
Old Mar 16, 2016 | 06:30 PM
Mike's SS's Avatar
I tried burping the system, but it still acts like it's not circulating. The radiator on the passenger side gets hot and the lower hose and driver side of the tank
is staying cool to touch. It's got a new t-stat from Napa in it, but I guess I'll get a new AC Delco one and try that.
Does anyone think that the water pump might be bad. And if so do you have to pull the motor to change it out?
Old Mar 16, 2016 | 06:37 PM
1 Yes 2 no
There is a water pump how-to posted in the how to library in this forum. hint: search "water pump".
Old Mar 16, 2016 | 06:43 PM
  #26
Originally Posted by donbrew
There is now a water pump how to in the how to library.
https://www.chevyhhr.net/forums/how-...acement-56476/
It's like deja-vu all over again!
Old Mar 16, 2016 | 07:40 PM
  #27
Mike's SS's Avatar
Yeah thanks again. I know I'm probably repeating my self but I'm just trying all the small suggestions first.
Old Mar 17, 2016 | 06:34 AM
  #28
Try just the thermostat first, the Napa one could be the problem!
Old Mar 23, 2021 | 12:56 PM
  #29
Beatngu305SS's Avatar
Parts
Originally Posted by Oldblue
A compression test and a coolant system pressure test will determine a bad head gasket.
I'm of the school, pull the head, have the machine shop do the valves and head surface
A new timing chain and gears set, a water pump and head gasket, and enjoy the SS for another decade or so
I blew the head on my 09 Chevy hhr SS turbo. I was trying to find the parts you mentioned, but their is so many and I am lost. I have no clue what part is what and where to get it from and what all I need for each. Thank you so much for your time!
Old Mar 23, 2021 | 03:04 PM
  #30
Are you looking at replacing the head? Need part numbers for the chains and and gaskets? LMK and I can PM you a grocery list of part numbers and sources ,
chrispacekc
Sep 28, 2020 07:26 PM
Jit
Oct 16, 2019 03:38 PM
twistedjay
Maintenance and Upkeep
Nov 1, 2015 09:38 AM
cj-five
Dec 7, 2014 03:29 PM
RvBum
Jun 1, 2014 11:18 PM
