Right Rear Door
Old Jun 28, 2007 | 06:30 AM
Goose's Avatar
I did the test this morning as both my rear doors would sometimes not close all the way unless you give them a little shove. With one of the front doors open there was no problem at all shutting either of the rear doors...close the front door and sometimes the rears will not close all the way...appears pressure is the culprit here
Goose
Old Jun 28, 2007 | 12:51 PM
Dan's HHR's Avatar
Originally Posted by GDZHHR
Sometimes the rear driver's side door needs a little extra umph when closing it on mine.
same here
Old Jul 8, 2007 | 04:55 AM
bisignano's Avatar
I just got my HHR back from the dealer. They stated that the right rear door is aligned properly and the seal is good. They are not sure why that door is the only one this happens too. They are going to contact GM. They have had 6 come in with the same problem.
Old Jul 9, 2007 | 05:44 PM
Originally Posted by Snoopy
Try rolling the frt. passenger or drivers window down about an inch or 2. Then try closing the right rear door. If the problem is not present, then it's just air compression preventing the door from closing properly
Originally Posted by the_shmoo
Got to be the inside air pressure
Not trying to challenge anyone with this question, but...............
If it's the inside air pressure, why wouldn't the front doors suffer from the same ailment? After all, I'm sure everyone has taken a solo ride in their HHR, and no one has ever complained about the driver's door being difficult to close.
Old Jul 9, 2007 | 06:33 PM
oneton's Avatar
I think that if you were to try the door that is hard to close from the outside and got in the car and try to close it, it will close better from the inside. Hard for a door to not close when your pulling it closed then letting it bump back from air.
Old Jul 9, 2007 | 06:45 PM
SandyBeach's Avatar
I cleaned out my car before taking it to the carwash and closed the back doors several times. I had no problem with them.
But one thing you have to consider is the weight of the back doors. They are very small and very light. Even the glass in the front doors is larger, adding more weight. Even a little air pressure inside can affect how they close.
I would suggest you make sure the front doors are closed last to eliminate this problem.
Old Jul 9, 2007 | 06:47 PM
ymerej_mortsdnil's Avatar
Cool
I have always had this issue but didn't really think too much of it. I just give it a little extra muscle & it shuts fine.
so to answer your ?, YES, I have this issue also...seems to be an 'HHR thing'...
Old Jul 9, 2007 | 06:51 PM
nfboy's Avatar
That is a good point. I do find my rear doors a little harder to close than the fronts sometimes, but that was also the case with my Mazda Protege 5 as well.
weissen
Dec 16, 2014 06:06 PM
Buck Meyers
Feb 29, 2012 03:05 PM
imredbeard
Apr 21, 2010 07:46 PM
dnbguy86
Nov 13, 2006 01:30 PM
Rob
Aug 31, 2006 10:41 PM
