Rough Running
Old May 12, 2013 | 07:56 PM
Eoj Nedraeb's Avatar
Rough Running
my 2007 hhr stopped running.
replaced battery.
replaced alternator.
now it runs rough.
check engine light is on and it displays (ENGINE SPEED REDUCED)
can anyone tell me whats wrong????
Old May 12, 2013 | 09:07 PM
Take it to your local auto parts store, Napa/Autozone/Advance/etc, and have the codes pulled. Once you get them, post them here and we'll have a better idea of what direction you should look in to fix the issue.
Old May 13, 2013 | 12:01 AM
X2 - without downloading the code from the engine check light, anything we can suggest would be a total guess. If the car is not drivable to the autoparts store, borrow a OBDII code reader (it must be CAN-compatible in order to get the codes to download).
Old May 13, 2013 | 02:21 PM
Maybe somebody should make an auto reply for "why is my CEL lit up?".
Old May 13, 2013 | 02:32 PM
Maybe a "Sticky" called "Check Engine light on, here's what to do", then give the steps needed in order to get the codes pulled for further diagnosis.
Old May 16, 2013 | 02:32 PM
cornwalis's Avatar
Spark plugs maybe or plug wire - boots
Old May 16, 2013 | 06:37 PM
ahhh, there are no spark plug wires............
hazelshome
Aug 21, 2015 08:20 PM
bigjacksauto
2.0L Performance Tech
61
Aug 21, 2013 04:51 PM
patokian
Jan 6, 2013 09:06 PM
408SS
Jul 26, 2012 08:31 AM
wagoneer
Oct 26, 2010 04:13 PM
