rough start, then runs fine. No codes
Old Oct 6, 2020 | 08:50 AM
  #51
fst100's Avatar
interesting!
Old Oct 6, 2020 | 10:31 AM
  #52
buslover's Avatar
The MAF sensor had a little dirt on it, as I cleaned with the spray I could see the liquid was darker. I cleaned it well....twice! The throttle body was pretty gunky. I had to spray, wipe with a towel or toothbrush, spray again, over and over, I cleaned it till it shined. So I am at a loss. I don't know what else to do. With it showing no codes, where would a shop or the dealer even start to look?
Old Oct 6, 2020 | 01:48 PM
  #53
buslover's Avatar
Nobody has mentioned dirty injectors as a possible cause. Is that possible? Would it make sense to run a can or 2 of Sea Foam or Techron through?
Old Oct 6, 2020 | 01:53 PM
  #54
fst100's Avatar
I read somewhere on here that since this is a direct injection the seafoam wouldn't do much in cleaning the valves. someone else who knows more on these DI motors could chime in, i'm still learning about these DI motors. I also read in another thread of someone having somewhat similar issues that involved the cam actuator?
edit-what about plug wires? I I highly doubt it but throwing it out there.
Old Oct 6, 2020 | 02:09 PM
  #55
There are no plug wires, and the only DI engine is the SS 2.0
Old Oct 6, 2020 | 02:11 PM
  #56
fst100
The OP has a 2007 HHR. It is not DI.
Plug wires ? These cars don't have them. They are coil-on-plug.
Old Oct 6, 2020 | 02:41 PM
  #57
You're drying the MAF sensor with a towel? You may have damaged it. It should just be sprayed clean and air dry. If it was as dirty as it sounds, it may be bad.
Old Oct 6, 2020 | 03:00 PM
  #58
buslover's Avatar
If you read my post again, I cleaned the TB with a towel after spraying with the TB cleaner
Old Oct 6, 2020 | 05:40 PM
  #59
fst100's Avatar
good to know! Thx for the corrections
Old Oct 6, 2020 | 06:43 PM
  #60
Run a tank or two with Techron added, can’t hurt!
