Rubbing Sound When Turning
Old Apr 13, 2013 | 07:19 PM
BunglerHHr's Avatar
Hello All,
I am having an issue in that I hear a rubbing sound when turning usually left but occasionally right. Sometimes it sounds like a mild grinding type sound. My Panel sounds fine when driving straight ahead and at highway speeds.
A visual inspection in the wheel well areas show nothing obvious.
Suggestions are welcome.
Thanks/BunglerHHr
Old Apr 13, 2013 | 07:26 PM
some more clues would be nice, but I will guess a hub is going.
Old Apr 13, 2013 | 10:32 PM
Hub or CV or brakes worn out. Pretty much covers it.
Old Apr 14, 2013 | 12:46 AM
Assuming you're running a stock size tire, or something slightly larger but properly sized, then I'll agree with Don....Hub, Outer CV Joint, or Brakes at the end of their service life.
Old Apr 14, 2013 | 01:26 AM
BunglerHHr's Avatar
My Ride is 2010 Panel LS with 22,000 miles
The sound I'm referring to usually occurs at slower speeds and only when turning.
Old Apr 14, 2013 | 07:38 AM
OK, one thing else that might be going on, but its a weird one.
My 2011 had a slow speed rubbing sound, mostly at walking speeds, checked out all the front end components with no failures found.
The real issue was a warped rear brake drum that was "catching" then releasing the brake shoes once every revolution. Once the drum was changed out, silence returned.
Have you tried jacking up each corner and rotating the wheels by hand? If you haven't, be sure to rotate each front wheel at full lock, turned both inwards and outwards.
Old Apr 14, 2013 | 11:14 AM
BunglerHHr's Avatar
@843de
No I haven't jacked up the Panel yet but I will. I had looked on this post:
https://www.chevyhhr.net/forums/problems-service-repairs-42/howling-grinding-clunk-crunch-squeak-squeal-noise-thread-45157/
Howling/Grinding/Clunk/Crunch/Squeak/Squeal Noise thread
From what was described it seems like the #2 fits the situation.
Strut bearing- Will grind, or vibrate with the steering wheel turning. Louder when stopped
I don't know anything about Strut bearings but will surely look into it.
It's hard to imagine that with only 22K on Panel Breaks or Wheel Bearings are an issue but we will see.
Thanks
Old Apr 14, 2013 | 11:29 AM
badassbowtie's Avatar
Originally Posted by BunglerHHr
@843de
https://www.chevyhhr.net/forums/showthread.php?t=45157
Thanks
In case you didn't already find it, the strut bearing is right at the top, can almost be seen under the hood, behind the windshield washer fluid reservoir on the passenger side, and behind the fuse box on the driver side
Old Apr 14, 2013 | 11:44 AM
BunglerHHr's Avatar
Well that surely clarifies this. Is the Bearing itself replaceable? Would this be covered by the 100K Warranty?
Old Apr 14, 2013 | 11:56 AM
I don't think you can do just the bearing, but I know its not under 100,000 mile warranty..
