S/C kit installed in 2006 HHR LT engine won’t crank
Old Oct 19, 2020 | 03:39 PM
jdcarpio2009's Avatar
I just installed the S/C kit in my car and there is power but engine will not crank/turn and help please
Old Oct 19, 2020 | 03:45 PM
Check your work, is the positive cable from the battery to the fuse box connected? Is the positive cable connected from there to the starter?
Are the ground wires reconnected?
these sound simple, but it only takes one to be over looked.
Something else to check, the battery, did you reconnect the negative cable?
Old Oct 19, 2020 | 04:17 PM
Nothing I can do from Virginia. Somebody left a wire loose or connected to the wrong place.
Old Oct 19, 2020 | 05:47 PM
Hi there I just rechecked and one there was not a good connection to the ECU, second I had connectors crossed I started it up wow, Im still waiting for the heat exchanger to come in but also Im looking for a Intake manifold block off plate its a big vacuum leak so yeah had to retract allot
Old Oct 19, 2020 | 05:54 PM
Hey, man you’re not the first to get wrenching and excited about first fire up and forget something, I now use my IPhone to record any lists I used to make in my head, I tell Siri to make a list.
granman
Jan 4, 2024 06:13 AM
Pamelalynnhunt
Mar 9, 2020 03:45 PM
John Shalanda Williams
Dec 12, 2017 11:44 AM
Terryjgill
Oct 12, 2015 08:08 PM
lever2k
Dec 16, 2014 12:18 AM
