Service Code P0016: Besides the timing chain, what should I replace?
Old Mar 7, 2019 | 03:25 PM
Lucidinferno's Avatar
Originally Posted by Oldblue
Water pump, I’m an AC Delco man myself
https://www.rockauto.com/en/catalog/...ater+pump,2208
we do receive a 5% discount from RockAuto.
Potentially stupid question: Why are two AC Delco water pumps listed? 252821 and 251751. I thought there might be an error, as they look different, but Advance has them listed as well. Are there two water pumps, and if so, which one do I need?
Old Mar 7, 2019 | 05:31 PM
The 'professional' grade is lower quality, the oem is better.
Old Mar 7, 2019 | 06:22 PM
The "Professional" is rebuilt. I don't have a problem with that.
Old Mar 7, 2019 | 07:00 PM
I'm I correct in thinking that I have no use for the specialty water pump holding tool, j43651?
Old Mar 7, 2019 | 07:23 PM
If you are removing the balance chain the tool is not needed.
Old Mar 7, 2019 | 07:39 PM
Thanks.
Old Mar 8, 2019 | 10:29 AM
I'm following the Haynes manual, and it says to remove the engine front cover I would need to remove the right engine mount. How necessary is this?
Old Mar 8, 2019 | 12:44 PM
No, simply cut the cross piece of tge front cover gasket, it’s the piece that is holding the gasket behind the engine mount
hurst2001
May 17, 2020 01:55 PM
tlink211
Jul 9, 2018 06:11 PM
carterbrenda53
Jul 1, 2017 07:45 AM
Junior864
Oct 12, 2012 02:39 PM
longislandhhr09
North East
10
May 12, 2010 06:05 PM
