Service ESC and Power Steering
Old Jul 26, 2021 | 01:04 PM
MagicSpoolBus08's Avatar
Both of these pop up at the same time and I have no clue where to start, or even what is causing this.
also when this happens I lose connection to my odb2 port.
any one have similar experiences?
Old Jul 26, 2021 | 01:11 PM
lazaino's Avatar
Are you loosing the OBDII port because of no power or no CAN signal? Does the scanner power up when you plug it in, if not, check the fuses and if you have a meter, make sure pins 4 and 5 are ground and pin 16 is 12V, even with the key off? If I was guessing I'd suggest a bad connection somewhere or a connector that's not fully plugged in or corroded. or maybe even a bad ground under the dash.
I
Old Jul 26, 2021 | 02:22 PM
Just to be clear. You are talking about a 2008 HHR SS ?
Old Jul 26, 2021 | 05:25 PM
I
i should’ve clarified.
I get a “no link” reading in my code scanner. Only does this when those two issues come up.
Old Jul 26, 2021 | 09:11 PM
Then you have a battery wire problem. I would start by looking at the rear connection on the outside of the under hood fuse box; that wire goes to the power steering.
Omnigear
Feb 25, 2019 08:29 PM
cloudhome
Nov 4, 2016 07:50 AM
Justice
Mar 8, 2015 08:46 AM
20HHRSS08
Dec 7, 2011 06:22 PM
mightymouse
0
May 17, 2010 03:34 PM
