Service traction light.
Old Feb 28, 2018 | 08:45 PM
Serpentsteeth's Avatar
Angry Service traction light.
I’ve been trying to diagnose what wrong with my traction control system but can’t find the answers I need...
Start up the car and the tc/esc come on and stays on. If i’m Driving and put it in neutral and turn off the ignition and restart it the tc/esc lights don’t pop on until I come to as stop. Now if I stop the HHR with the E brake using the above method the tc/esc will not come on, however if I depress the brake pedal the tc/esc Light come on.
Does anyone have an idea what could be malfunctioning? All the harnesses are tight and the wires look good, I also checked the brake fluid that’s fine too.
Old Feb 28, 2018 | 09:04 PM
It sounds like a hub problem, but to determine which one you need to use a OBDII code reader that will read more than just the basic engine codes. Did you check the wiring for the system at each hub - could be a broken wire or bad connection.
Old Feb 28, 2018 | 09:16 PM
I checked all the wires and connections. I’m not so sure it’s the hub sensors. I can stop perfectly fine time after time with the E brake and even sit in park, but if I depressed the brake pedal while stoped the tc/esc lights pop on. Frustrating as hell. Also I changed both hub bearings over the summer.
Old Feb 28, 2018 | 09:18 PM
You haven't said if the CEL is on, or if you've had a code reader on it. It could be a vacuum problem, seems like everytime it comes on is when you step on the brake pedal.
Old Feb 28, 2018 | 09:19 PM
then you will need to use an advanced OBDII code reader that will read more than just the basic engine codes.
What about the remaining hubs?
Old Feb 28, 2018 | 09:21 PM
No cel, the odd thing is that it’s only when i’m At a complete stop. Braking doesn’t trigger it while driving. Only if I come to a full stop with the brake pedal.
Old Feb 28, 2018 | 09:35 PM
Whopper, no I haven’t replace the rear hubs, nor have I checked for codes.
Old Mar 1, 2018 | 07:12 AM
Brake fluid? Brake pads/shoes?
Old Mar 1, 2018 | 07:41 AM
Donbrew, all those are in good working order and brake fluid is good too.
Old Mar 5, 2018 | 09:13 AM
PittKrewBowling's Avatar
I know this sounds crazy, but check the air pressure in all your tires. This happened to me last night SERVICE ESC on the DIC. Sure enough, I had a really low tire. Inflated tire and light has not come on since.
