Service traction light.
Old Mar 29, 2018 | 04:12 PM
Cool - sounds like you are ready to roll.
Old Apr 2, 2018 | 07:54 PM
Still running fine?
Old Apr 2, 2018 | 08:22 PM
kamikaze3557's Avatar
Still running fine, It's true I need to see if there are any codes? I read that the auto parts places will do it for free (in hopes to sell you something I'd bet) I may have firestone do it when I have them do the sway bar bushings. I really wan't to get one of those readers for myself. But no check engine light. I do need to flush out the coolant, think I mentioned that in another post... no chemical flush I'm reading, just distilled water, and put in a new thermostat ACDelco 131-158..if I'm remembering correctly.....
Thanks for checking in ..
Mike
Old Apr 3, 2018 | 07:07 AM
That’s the correct thermostat, with 50/50 Dexcool
Old Apr 23, 2018 | 08:43 PM
NBlades's Avatar
If your Service Traction/Service ESC/ESC off comes on and you get no physical codes when you hook up the reader then check to see if you have mud/dirt packed into the wheel assembly area. This is what was my issue causing the sensors to go off. No need to replace the speed harness sensor (like the dealer wants to do).
Old Apr 23, 2018 | 09:20 PM
  #26
Good information. I had dried mud inside one of my wheels once, the vibrations were harsh!
I've deleted your other, similar posts in other (dead)threads.
Old Apr 23, 2018 | 09:26 PM
  #27
NBlades's Avatar
Actually it wasn't dried in the wheel rims, it was under the vehicle/frame area. But yes, the vibrations are crazy from the rim build up. My husbands Ford Windstar used to throw Tire Pressure warnings when his were off balance.
vrg813
Aug 25, 2018 04:27 PM
Cascious King
May 8, 2014 08:50 PM
dlmhhr
Dec 28, 2013 12:43 AM
Lake Runner
Dec 10, 2012 09:33 AM
Marzipan
Dec 19, 2008 10:18 PM
