Solenoid not engaging after motor rebuild
Old Jun 26, 2015 | 05:56 PM
vanLienden's Avatar
Got it working then had a bad new timing tensioner, pulled everything back out as couldn't imagine messing up the chain sequence. Everything is back in and now once I turn the key to engage the starter (we have it hooked to a test light right now) it activates it, the second time we try it does not. We have to pull the key out wait a little bit re insert it and then the same thing, first time to ignition light off the solenoid wire lights but then not again.
Old Jun 26, 2015 | 08:06 PM
That might have something to do with the way the starter works. Normally you just turn the key to "start" and let go of it; the starter runs until the motor starts or it times out. There is probably a delay in it also, like an A/C compressor has to wait 2 minutes before it can restart.
Don't know for sure, though.
nate71
Drivetrain (Excluding Engine)
15
Sep 11, 2019 07:48 AM
Rocket Dawg
Maintenance and Upkeep
17
May 19, 2015 09:12 AM
bhamsoxfan
Nov 24, 2013 11:12 AM
2007HHRLT
Feb 8, 2013 07:17 PM
harleysshhr
May 10, 2010 08:49 PM
