sound on the passenger side front tire and driver side don't speed up
Old Sep 21, 2020 | 04:45 PM
tomasorta's Avatar
Exclamation sound on the passenger side front tire and driver side don't speed up
Hi , I have a problem with the front tires, I jack the on the front car lift front tire at the same time I enaged the first gear(manual transmission) an dI hear a noise front the passenger side, I test with both hand to move in 3 and 9 and 6 and 12 and feel a movement , I check in the youtube video and could be the wheel bearing according with the same sound like a plane sound, but in the driver side don't speed up the tire, almost stop try to speed but a litte slow and stop,meanwhile the passenger is speed up with that noise but speed up fast the driver side don't speed up don't move(both tire are lift with the jack)
so I need some help please, what part need to be replace on the driver side? , the passenger is just to replace the wheel bearing but in the driver side what part?
thanks
thanks
Old Sep 21, 2020 | 06:13 PM
If you mean only one wheel spins when in gear, that is normal. That is the way a differential works. You should not run in gear when both there is no load on the front suspension, you could mess the CV joints up.
I would replace both hubs at the same time.
Old Sep 21, 2020 | 06:19 PM
tomasorta's Avatar
Thanks for you advise.
close this thread
Old Sep 21, 2020 | 07:52 PM
So, it is written, so it shall be done! Closed.
cturboaddict
Aug 28, 2024 07:11 PM
HHRnovice
Aug 18, 2020 09:06 AM
LawDog88
Apr 4, 2014 10:53 PM
Alexwsilver2010
Sep 9, 2012 03:04 PM
Goose
Feb 13, 2010 05:48 PM
