Speedometer spikes and stalls
Old Oct 29, 2022 | 11:35 AM
chris1775's Avatar
My wife has a 2011 HHR LT, don't recall the miles but I think it's over 130k.
This year its been acting up in that the speedometer will act erratic even at a stop, sometimes when moving from a stop, it'll stall and die and the only code is from an anti theft sensor. I've replaced the sensors on top of the motor and it was OK for a few days but then was right back at it. Just a few months ago she took it in for the ignition recall thinking that was the problem and it was OK for a week but nothing has fixed it. Is this a common issue or does a legit mechanic need to get hands on it? I've even tried cleaning the throttle body to no affect.
As a side note, we know there's a transmission leak from the previous owner who boogered the pan install but would that make a water trickling sound on acceleration if the fluid is low?
If this post is dupe, I apologize, I simply don't know what search terms I'd use to find pointers in this forum.
Old Oct 29, 2022 | 11:40 AM
It could be the speed module on the transmission isn’t getting fluid. Water gurgling is usually the coolant in low and air got into the system.
Old Oct 29, 2022 | 11:44 AM
chris1775's Avatar
That for the response. My immediate thoughts are adding/replacing Trans fluid and checking the coolant, add as needed, correct?
Old Oct 29, 2022 | 12:13 PM
If the coolant is low in under the rad cap, burp the coolant
https://www.chevyhhr.net/forums/how-...-system-60614/
To check transmission fluid, you remove the 11mm plug on the passenger side , it’s full when fluid drips out, check it warm and on a level surface. Or if the pan gasket is leaking anyway
https://www.chevyhhr.net/forums/how-...-change-58325/
Old Oct 29, 2022 | 07:20 PM
Have you checked the battery? The alternator? The AC compressor?
Any CheckEngineLight you forgot to mention? Any strange sounds? Any work done just before this started?
Old Oct 31, 2022 | 08:32 AM
geg's Avatar
geg
the speedometer receives information from the transmission - you need to look for a goblin there!
Well, check the electrical contacts to clear your conscience
chris1775
Maintenance and Upkeep
Aug 3, 2022 08:54 AM
skyline26
GM Recall Campaigns
44
Dec 16, 2019 08:21 PM
Cliffs51
GM Recall Campaigns
14
Jun 5, 2018 10:39 PM
Tanya Barnes
Jan 20, 2017 10:04 AM
mikelikestobike
GM Recall Campaigns
Apr 2, 2014 10:49 AM
