Spindle nut
Old Sep 8, 2021 | 08:49 PM
HHRnovice's Avatar
Spindle nut
I have tried removing the spindle nut on my 2009 LT but it won't budge. I have heated it with MAP gas, applied a lot of penetrating oil and let it soak but no luck. Using a breaker bar and extension pipe doesn't help. I have heard that using impact wrenches isn't a good idea for this although I've seen mechanics do just that. I do have an impact wrench that is a 12v electric type that is a bit different than the usual impact wrenches. It builds up momentum and then releases one sharp blow to do the job. I am wondering if using this impact wrench might round off the nut or damage the axle or CV.
Old Sep 8, 2021 | 09:24 PM
Don't use impact to INSTALL. Fine to remove. The danger is cross threading and over torqueing.
Old Sep 9, 2021 | 05:57 AM
Use the impact and the correct size socket. It should be a 30 mm
Old Sep 9, 2021 | 03:25 PM
HHRnovice's Avatar
I will try my impact to remove the nut. It is 30mm. I have a torque wrench to install it if I can get it off. Thanks.
Old Sep 9, 2021 | 03:42 PM
I suggest you order a new nut.
Hub axle nut - for FE1 and FE3 only - Use GM PN10289657 - NOTE: GM specifies they must be replaced, and not reused.
Old Sep 9, 2021 | 06:13 PM
HHRnovice's Avatar
Yes, it's important to use a new spindle nut. My local NAPA has them in stock at a decent price. I will get a new one.
Dferris
Apr 28, 2021 07:04 AM
C3P0
Drivetrain (Excluding Engine)
Sep 13, 2018 07:51 PM
Teamecotec
May 23, 2017 09:43 AM
maddawg
Aug 12, 2014 10:21 PM
oldracer
Maintenance and Upkeep
10
Feb 7, 2014 01:06 PM
