SS Brembo Brake Noise
Old Dec 14, 2010 | 09:29 PM
Sidecardog1's Avatar
I have a 2010 SS with 14,900 miles on it. It has the performance package with the Brembo's up front and the LSD. About 200 miles back the brakes started making a high pitch squeal noise ONLY when the car is about to come to a full stop. It is perfectly quiet during all other braking, then as you roll to a stop the last few feet the noise starts up. Took it to the dealer, they put it on the lift and said everything looks fine. Then they showed me Bulletin #08-05-22-004A that was issued May20, 2010. The bulletin applies to 2008-2010 Cobalt SS & HHR SS. Basically it tells the dealer to do nothing except explain the bulletin to the customer saying that this noise is a normal characteristic of the high performance braking system.
Has anyone else experienced this annoying sound and more importantly, was there a fix identified that works?
The only thing I can see/feel is a slight ridge on each outer surface of the disk where the pads wear. The only thing I can see that could be done would be to cut/grind down those ridges that are left at the edge of the pads wear path on the disks. Any other ideas or solutions? Thanks guys.
Old Dec 14, 2010 | 10:00 PM
c2vette's Avatar
I have had mine for over 35,000 miles with no noise ever. If the dealer won't do it, and if you are not comfortable doing it yourself, then go to a brake shop and have them put some anti-squeal compound between the shim and the back of the pads. Ideally let it cure before you use the brakes.
Old Dec 15, 2010 | 06:40 PM
NUCAR's Avatar
This is a characteristic of the Brembo's. It is the price you pay for the high speed stopping performance. I hear this on the Camaro SS as well. They certainly squeal less than the brakes on a race car coming back into the pits. I would not worry too much about it as it is a indication you have a high performance braking system. You might want to consider a Hawk pad when they need to be replaced. Hard high speed stops may help to deglaze the rotors. Getting the turbo upgrade will help with this
Old Dec 15, 2010 | 08:33 PM
c2vette's Avatar
True, "squeal" is characteristic of many disc brake setups, however it is also true that it is easy to "cure" by simply properly applying anti-squeal compound to the backing plates (and in this case between the plates and the shims). If it does not bother you, fine but not that big a deal to fix it.
Old Dec 15, 2010 | 10:11 PM
Thanks guys, I'll give those suggestions a try and see what transpires. I already have the power upgrade which is probably why the brakes started making the noise after having to slow down quickly before I get myself into hotwater with the local radar operators here!
Old Dec 17, 2010 | 03:29 PM
Why is this front page news?
gmdealerguy
Jun 26, 2022 09:24 AM
VictorySpeedway
Feb 21, 2011 05:35 PM
Father Azmodius
7
Feb 17, 2010 08:35 AM
fasterbbc
Jul 16, 2009 05:29 PM
