Steering issues
Old Mar 13, 2019 | 02:20 PM
See post #14.
Old Mar 13, 2019 | 02:42 PM
Has the steering wheel been removed, is it off center?
Old Mar 13, 2019 | 03:16 PM
C-rad's Avatar
Steering issues
Steering wheel has not been removed but, is just s little off center.
Old Mar 13, 2019 | 03:18 PM
C-rad's Avatar
Steering issues
#14, will it through a code for that sensor or is it all connected to the ABS sensor?
Old Mar 13, 2019 | 04:21 PM
Without the codes, nobody knows. If the steering wheel is off the steering torque sensor needs to be recalibated and the wheel needs to be centered.
Old Mar 13, 2019 | 04:22 PM
  #26
C-rad's Avatar
Steering issues
Great information. Thanks I'll try to get those codes and post this evening.
Old Mar 13, 2019 | 07:32 PM
  #27
C-rad's Avatar
Alright, ABS code is C0050.
Old Mar 13, 2019 | 07:54 PM
  #28
fastsuv's Avatar
C0050 is the right rear wheel speed sensor.
Steve
Old Mar 13, 2019 | 07:57 PM
  #29
C-rad's Avatar
Would that have any effect on the front steering?
Old Mar 13, 2019 | 07:59 PM
  #30
fastsuv's Avatar
Since you don't have traction control (5-speed manual) and I don't think stability control was even offered in 2007, there doesn't seem to be any system that could be malfunctioning and causing the swerving back and forth.
I still think you have something loose somewhere or badly worn.
Did you check the strut bolts? Both at the top and at the bottom connections?
Back in the early nineties I had strut bolts loosen (after a dealer changed them out) on a car and it would shudder side-to side above a certain speed.
Steve
