Steering issues
Old Mar 14, 2019 | 12:14 PM
  #41
C-rad's Avatar
Steve, the left to right sway started before I started replacing parts.
The first problem I had was front breaks and a humm in the passenger side front wheel hub assembliy. I couldn't get it fixed right away (no$$). The front end started the shimmy and shaking and then the swaying before I could get it fixed. I was able to start getting parts and doing the work. The breaks and hub got done. The shaking kept going, and a little more movement (swaying) in the front end started. I replaced the lower control arms and ball joints (both sides) and the drivers side CV (popping when turning). The shimmy and shaking stopped but the sway got worse. I replaced the rack and pinion and tie rods. The swaying changed from on acceleration/deceleration/shifting to the current sway while driving. I changed out the tires and that didn't help. I replaced the sway bar bushings and sway links. No change in sway while driving. I replaced the intermediate steering shaft yesterday and it didn't make any difference in the swaying. I'm going to replace the struts ( since I already have them) but the only other thing I could think of to replace is the passenger side CV. I still have to check the carriage bolts and double check the strut mounts.
I hope this helps.
Old Mar 14, 2019 | 03:31 PM
  #42
"swaying while driving" We just can't conceive that a loose hub could do that?
I have had one with so much play that the rear camber was noticeable with the bare eye.
Old Mar 15, 2019 | 02:22 PM
  #43
C-rad's Avatar
Originally Posted by fastsuv
I still think you have something loose somewhere or badly worn.
Did you check the strut bolts? Both at the top and at the bottom connections?
Steve
All bolts and connections look good and feel tight top and bottom.
Old Mar 15, 2019 | 03:08 PM
  #44
You say that the steering wheel hardly moves with it does that jerking from one side to the other. Have you looked at the REAR suspension at all?
Old Mar 15, 2019 | 04:00 PM
  #45
I gave up on that.
Old Mar 15, 2019 | 04:19 PM
  #46
He has thrown way too much money, effort, and time into it already, to resolve a problem that surely can't be that hard to diagnose if one actually lays hands on it.
It doesn't look like trying to resolve it via the internet with a game of 20 questions is going to resolve anything IMO.
Old Mar 16, 2019 | 11:10 AM
  #47
C-rad's Avatar
Yes, I replaced the shocks about 3 weeks ago.
Old Mar 16, 2019 | 11:51 AM
  #48
Replaced the shocks, did you inspect the axle pivot bushings?
Old Mar 16, 2019 | 12:00 PM
  #49
C-rad's Avatar
No. Could that make the front end do what its doing?
Old Mar 16, 2019 | 12:15 PM
  #50
It could.
