Steering rack and pinion failure
Old Jul 21, 2017 | 08:04 AM
If the ball joint is worn out the rear bushings could also be toast!
Old Jul 21, 2017 | 08:11 AM
aradmahogany's Avatar
Agreed. Replace the Control arm as a whole with all new bushings, the correct aluminum unit of course. Your mechanic will most likely, unless they are super honest, overcharge you incredibly for this job. Depending on where you live, dont be surprised if they have trouble with the rear LCA bushing bolt, especially if that bushing is .
Old Jul 25, 2017 | 03:38 AM
JimDaddyo's Avatar
All done, alignment done, drives like new.
Old Jul 25, 2017 | 08:19 AM
All done? Which parts were used? Just a ball joint or LCA's
Old Jul 27, 2017 | 08:25 AM
JimDaddyo's Avatar
Just one lower ball joint from NAPA. The old one was just barely worn so I got it changed just to keep on top of things, besides, with the rack being replaced I wanted to get an alignment job. The first time I have had it done and I have had the car since new. There was never any indication of it going out of alignment, so with parts replacement it was a good time to have it checked.
Old Jul 27, 2017 | 09:06 AM
Agreed. Thanks for the follow up.
Old Jul 27, 2017 | 09:55 AM
No joke since I realized my tires were low on air "each was around 25-26 PSI) I pumped them up to 35 PSI each and HOLY HELL the car is actually a ton smoother going down the road. Maybe placebo, maybe not, but I feel like it is!
Old Jul 27, 2017 | 11:00 AM
What does the placard say on the door jamb? Mine says 32 PSI. A very comfortable ride.
Old Jul 27, 2017 | 12:20 PM
Mine also says 32.
Grizzly old man
10
Jan 15, 2015 02:08 PM
kable
Feb 14, 2014 09:30 PM
cbxjeff
Feb 4, 2014 03:08 PM
jbg141
Mar 11, 2010 08:34 PM
