Steering wheel rocks to and fro
Hello, Youtubers. No, wait - wrong place.
At slow speeds the steering wheel goes left and right, especially in corners. As the speed increases, this wobbling goes away. I lifted the vehicle, and the LCA bushings all seem tight, and there is no play in either tie rod end. Rack boots are intact, with no sign of leakage. The tires seem round (spun and gauged against the bottom of the strut). I detect no tread separation. No unusual tire wear at this point. The rotors don't appear to be warped, which (methinks) would present itself at higher speeds and with brake application.
Thoughts?
Thoughts?
Did you check the lower ball joints? Is the steering wheel centered or does it sit off-centre when going straight down the road?
How about the play in the hubs? Any up and down slop? Or any noise from the hubs while driving?
When I had a lower ball joint that got sloppy and needed replacement, the steering wheel went off-centre (towards the opposite side of the worn ball joint).
Have you done any front end repairs/replacements in the last year?
