Sunroof won't slide back
Old Jun 14, 2023 | 02:48 PM
mongo's Avatar
How tiny? In the problem I described in comment #2 above, the broken piece is about an inch long with a hook on the end that catches the deflector. Then the deflector gets skewed an jams up the works. This is a common problem. There is a TSB on it. It seems some owners have successfully put the broken piece back in place with JB Weld (which is not the TSB recommendation.) It was discussed in at least one thread here but I couldn't find it.
First I discovered that I could open and close the sunroof by moving it in small increments while manipulating the deflector. (I have long arms.) Then I realized that just removing the deflector allowed normal opening and closing. Driving without the deflector sucks tho.
The problem is it will not move at all. I have so far spent about 12 hours over the past few days trying to manipulate the sunroof open far enough to get to the deflector or at least see waht is in there. At this point, I am pretty sure it's not jammed, but whatever pulls the sunroof back on that side is broken. I have spent way more time trying to cheat this than if I had just pulled the sunroof out from the start.
Old Jun 14, 2023 | 08:11 PM
mongo's Avatar
It seems no one else has had this exact problem here or on Facebook, so I gave it one last ditch effort. Using plastic trim pry bars and a LOT of back and forth with the switch, I got it to break free, and it opened with a lot of scraping noises. Once open,I found the track to be badly gouged, probably from the hook shaped piece of steel I fished out with a magnet. I smoothed it out with some emery cloth and greased it up. The sunroof now works smooth as new.
I swear, whenever I have a problem with a vehicle that isn't super obvious, it's also something no one else has ever seen.
The wind deflector is fine, I think something just got in the track when the sunroof was open. I use the full open more often than the vent position.
The tools used
Gouged up track
clean track on driver side for comparison
Old Jun 15, 2023 | 02:28 AM
PulpFriction's Avatar
Glad you got it to work. Hoping for a pic of the "hook shaped" piece. Does the deflector work?
Old Jun 15, 2023 | 06:26 AM
He says the wind deflector is fine.
glad it’s working, I saw kits on flea bay for parts of Gm sunroofs maybe they have pieces to replace the hook piece
Old Jun 18, 2023 | 12:18 AM
mongo's Avatar
Can't find the piece I fished out with the magnet, I dropped it when I was trying to get a pic. But, it's been a few days and it still works, so I'll take it.
OKIE SS
Oct 23, 2021 05:08 PM
jcrill
Aug 10, 2012 02:39 PM
andoll83
Jan 3, 2008 03:08 PM
MOTRV8D
Jun 11, 2007 07:44 PM
Teflonworm
Jul 24, 2006 07:40 AM
