Temperature Gauge????
Old Feb 4, 2025 | 10:00 AM
pakrat's Avatar
I've got a 2006 LT, with the 2.4l
This morning as I pulled into the parking lot at work I noticed the temperature gauge was not registering. I toggled through to the get the temperature on the LED dash readout - and it showed nothing at all.
I've check the coolant level, it's fine.
I then checked the oil, no "milk" in the oil (thankfully)
Do I have a bad sensor somewhere?
Any help would really be appreciated.
Old Feb 4, 2025 | 10:25 AM
You need a new thermostat, ACDelco 131-158, accept no substitute.
Old Feb 4, 2025 | 10:45 AM
pakrat's Avatar
Very much appreciated.
A faulty thermostat will cause the gauge not to register?
Do you happen to have the part numbers for the water pump, and radiator hoses? I figure that while I'm at it I should go ahead and change them all out too.
Old Feb 4, 2025 | 11:58 AM
PulpFriction's Avatar
Before you draw any conclusions, you should check a few things. Have you confirmed coolant level under the pressure cap? And what is the driver information console (DIC) say? You can access the coolant temperature by cycling the third button down on the left side of the steering wheel. It should give a reading even with the engine stone cold. If it doesn’t, it’s more likely a problem with the coolant temperature sensor.
Sure, a stuck open thermostat could keep the gauge from registering, but not the DIC reading. It should also result in a DTC. You should also scan for codes.
For Pete’s sake, do not change a perfectly good water pump because of this. Hoses should be inspected regularly and replaced when needed.
Old Feb 4, 2025 | 12:19 PM
If your coolant is 5 years old or older change it! A bad thermostat will give you —— on the DIC and possibly code P0128. For the age and cost you can change the temperature sending unit. Part numbers are in this thread
https://www.chevyhhr.net/forums/comm...-thread-48833/
bare in mind some these can be obsolete . Does your 2006 , 2.4 litre have the external oil cooler, different hoses for that set up
https://www.rockauto.com/en/catalog/...tor+hose,10068
Old Feb 4, 2025 | 09:20 PM
Gearhead1's Avatar
…and water pump is pretty involved to change
Old Feb 5, 2025 | 06:59 AM
Best to change water pump and timing chain at the same time!
Old Feb 5, 2025 | 11:53 AM
jimvw's Avatar
If you reset error codes your display will work for a short time, but you should replace thermostat as stated above. Been there, also when the temp does not display, it will lock out the air conditioner and run the fan all the time.
Old Feb 5, 2025 | 12:48 PM
The water pump is not something to change "while you're in there" changing the thermostat. Completely different job.
I could see maybe changing the hoses while you're there, but even then, removing hoses from the thermostat housing is not necessary to change the thermostat.
ScottyB
Jun 8, 2023 10:40 AM
DuncanJ1907
May 14, 2022 06:39 AM
letterman7
Aug 1, 2021 10:05 PM
Ed ke6bnl
May 14, 2021 08:44 AM
HHR911
Aug 22, 2012 12:10 PM
