test don't guess ECM 2008 HHR2.2
Old Apr 10, 2020 | 05:22 AM
Cat Man HHR's Avatar
Jumper wire is from socket 87 to socket 30.
This is on a Ford, but like Don said, all relays are labeled the same.
Old Apr 10, 2020 | 08:15 AM
https://www.chevyhhr.net/forums/prob...m-works-58456/
Old Apr 10, 2020 | 02:17 PM
I moved all of isolated's stuff to this thread he started earlier, then started posting in another thread. Maybe solves confusion.
Old Apr 10, 2020 | 08:58 PM
Isolated's Avatar
Originally Posted by donbrew
Just for kix try jumping the run and start relay.
Fuse #5 Pin 30 is the supply for the start relay, it is always hot. . Signal is pin #86 (hot)
Pin 30 on the run relay is always hot. Signal is pin # 85 (hot)
If those pins are not always hot there is an internal fault of the fuse box.
pin 30 is hot but 85 and 86 and 87 are not. We jumped 30 to 87 and the starter spun which was a very welcome sound. But still no start. We split the fuse box but saw no obvious problem. What next?
Old Apr 10, 2020 | 09:04 PM
Another post moved, please keep it here in your thread, isolated.
Old Apr 10, 2020 | 10:12 PM
  #26
Try switching relays.
Old Apr 11, 2020 | 01:17 AM
  #27
Isolated's Avatar
we dd switch relays. did not make a difference. I guess I do not understand the difference between a post and a thread but I am happy to proceed with whichever format you prefer. It has often been said that my technology elevator does not go to the top floor.
Old Apr 11, 2020 | 01:21 AM
  #28
Isolated's Avatar
I will have a look at the neutral safety switch. I have found the ground wire voltage sensor . what does it do and how can i tell if it is damaged?
Old Apr 11, 2020 | 04:12 AM
  #29
Read this, it will explain the function of that sensor.
Old Apr 13, 2020 | 03:04 PM
  #30
Isolated's Avatar
I removed top of fuse box but both halves look perfect. pin 30 is hot but 85 and 86 and 87 are not. Could the problem be the power coming into the fuse box ?
Hard to believe that the power will go through a jumper wire but not through a good relay. I have tried switching relays
